Which heads to get?
Old 10-30-2004, 12:04 AM
Drew778's Avatar
Default Which heads to get?
looking for new heads, what is the best choice out there?
Thanks
Andrew
Old 10-30-2004, 12:17 AM
jrp
SN95 Director
jrp's Avatar
PP to AFR and everything in between.
it would help us if you at least gave us a budget and what your looking to get out of them.
Old 10-30-2004, 12:46 AM
Drew778's Avatar
Well, if AFR are worth the extra money, I'll pay it.
My Plan is to go 10's n/a, I'm also looking into a new botton end.
I called SLP today about the ZL-402 and I'm not paying $100 crate fee, $400-500 just Cali, when I'm in Hawaii
I'd like to stay under $6K if possible for everything
Old 10-30-2004, 07:30 AM
jermstyle's Avatar
A 408 with some Stage 3 TEA AFR's and a FAST 90/90 would do the trick.
I'm not sure on cost/shipping though for this, the heads are around 2900 but they are for > 3.900 bore.
Old 10-30-2004, 12:08 PM
Suspended Sponsor Account
ForceFed HP's Avatar
give us a call, we can probably help you out and keep it in that price range, depending on your setup options
Old 10-31-2004, 10:06 AM
LS1SS4ever's Avatar
there are another choice which are MTI or Patriot
Old 10-31-2004, 12:50 PM
Drew778's Avatar
Well, I have Patriot 5.3L Stage 2 heads now, I had some problems, dual springs that came with them one broke after 3000 miles.
The second set that Terry sent for free, I got valve float on #6 and #3 cylinder and the piston hit the valve.
Old 10-31-2004, 01:04 PM
Cobraeater's Avatar
Question
Were the springs the Patriot "Gold" or were they brown-grey springs from Patriot?
Old 10-31-2004, 03:13 PM
Drew778's Avatar
They were the older bigger diameter springs, Not the gold.
Plus I have the shift points at 6000 rpms
Old 10-31-2004, 06:42 PM
nuzee's Avatar
I have a set of stock rocker arms that you can have if you want.
I know of a way to get heavy stuff shipped to Hawaii for $1 per lb. Only problem is is that you have to pay shipping to their location. Let me know if you want me to check into it further.
*cough*lingenfelter*cough*
Old 10-31-2004, 07:20 PM
Drew778's Avatar
Thanks, I don't know shipping on that going to be
Old 11-01-2004, 06:13 AM
racrx's Avatar
FORCE FED HIGH PERFORMANCE!!!!!!!!!!!!!!!!! Brad or Scott Waldon you wont do any better imho, peace, victor
Old 11-01-2004, 02:22 PM
Cobraeater's Avatar
Post
Patriot had alot of people breaking the first Patriot dual springs, and then after that they went to the "gold" dual springs which have not had a reported break yet in almost a year of use.
I hope you didn't have too much damage from the spring breaks.
Anyway, I would go with TEA, Absolute (might have to wait 6months to a year for those ), or wait for the AFR 225's, which could make the most power, and are supposed to come out in December or January.
Old 11-01-2004, 03:11 PM
11 Bravo's Avatar
Ditto. It was a long hard decision for me because most of the people on the right have killer heads, but in the end I went with FFHP.
Old 11-01-2004, 03:22 PM
CamaroCain's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/208929-prc-225-cam-prc-stage-2-5-5-3-heads.html
https://ls1tech.com/forums/dynamometer-results-comparisons/207313-tsp-magic-stick-prc-heads-a4-dyno-results.html
https://ls1tech.com/forums/generation-iii-internal-engine/208941-new-brand-heads.html
