Oil temp in new motor
Old 10-30-2004, 02:58 PM
Greg Fell's Avatar
Question Oil temp in new motor
I have a new motor with ~ 400 miles on it. I have noticed that the oil temp is higher than it was in my old motor. Is this normal during break in? FYI I used mobil 1 or royal purple 5w30 before. I'm assuming there is dino oil in it now.
Oil temp gets up to about 190 or so. Before it was rarely over 175-180. It has awesome oil pressure as well.
Old 10-30-2004, 08:55 PM
jz06man's Avatar
Mine runs 195-200 normally and 205-220 when I'm running her hard..
This temp is normal.... or abit low..
if oil pressure is ok, then don't worry.
Old 10-31-2004, 03:58 AM
Patman's Avatar
My oil temp usually runs around 205 at steady highway speeds.
175-180 is too low actually, you won't effectively get rid of all the moisture from the oil with the temp that low, especially if you only do short trips.
Old 10-31-2004, 03:15 PM
jz06man's Avatar
Patman is correct, this oil temp you are running will not burn off the water/moister in the oil.
Old 10-31-2004, 07:05 PM
Greg Fell's Avatar
My oil pressure is about 28 when hot at idle. What are you guys getting? My old motor only saw 10.
Old 10-31-2004, 07:48 PM
jz06man's Avatar
28 seems ok... mine is 30-32 when hot... 10 is/was too low...
My running hot pressure is about 45-53.
Old 10-31-2004, 07:50 PM
jz06man's Avatar
My friends new C6 is 27-28 idle when hot..
Old 11-01-2004, 04:13 AM
Patman's Avatar
Mine is also 28-29psi at idle once the oil temp is around 200F.
