New setup running-SLP 402, AFR, MS3
Old 10-31-2004, 11:47 AM
max's dad's Avatar
Default New setup running-SLP 402, AFR, MS3
Assembled Friday, and installed Saturday. Set up uses the slp 402, afr heads milled .035 to give 11.6, and the TSP MS3. Other parts include LSX 90mm intake and TB, 85mm MAF, and Edelbrock stepped 1 3/4 to 1 7/8 race header with ORY. Car has the Ram steel flywheel and 4.10s in a ten bolt. I'll have numbers Monday.
Old 10-31-2004, 12:35 PM
Moderator
thechef's Avatar
i am very curious to see these results
what are the cam specs???????????
Old 10-31-2004, 04:17 PM
tdogg5.3's Avatar
same thing i was wondering, need a good cam for my 383
Old 10-31-2004, 04:59 PM
CHRISPY's Avatar
Great stuff
Did you port the AFRs at all?
Please post your results in the dyno section
Old 10-31-2004, 05:12 PM
max's dad's Avatar
Head were untouched except for milling. Cam: 237/242 .603/.609 113
My plan was for great street manners and good torque.
Old 10-31-2004, 05:17 PM
H82BBad's Avatar
how does it feel? It will be intersting how much power it turns out with that head. I doubt it is enough head for a 402 but it may surprise me. You milled the heads but did not open the chamber up to a 4 inch bore?
Old 11-01-2004, 07:41 AM
vmax1500's Avatar
I am very curious to see what kind of numbers this puts down... do you have 12 bolt or 9 inch lined up for when your rear end explodes ?
Old 11-01-2004, 08:01 AM
Hardtop's Avatar
My thoughts exactly. First time it hooks just a bit>>>>>> Sounds like a nice setup on the motor.
Bruce
Old 11-01-2004, 11:13 AM
vmax1500's Avatar
Bruce
I think it might actually blow up on the dyno!!!
Old 11-01-2004, 12:39 PM
Turo's Avatar
Originally Posted by max's dad
...I'll have numbers Monday.
waiting patiently...
Old 11-01-2004, 02:15 PM
vmax1500's Avatar
I hope the rear end did not destroy the dyno... I am looking for 500RWHP and 480lb-ft!
POST THE NUMBERS !
Old 11-01-2004, 02:22 PM
vmax1500's Avatar
Based on some other postings I saw from you, I assume Mike @ Rapid is building this for you... Based on the price of the shortblock, heads and cam I assume you are at about $6500 in parts... how much is he charging to build the actual motor and what was his impression of the SLP short block after recieving and inspecting it?
Old 11-01-2004, 05:47 PM
max's dad's Avatar
Numbers are in the dyno section. (508.7 rwhp and 489.6 rwt) The only initial issue is this thing smokes like crazy when hammered. I'm hoping the rings will seat with some miles, but it does concern me.
Thanks for the reminder about my ten bolt!
Old 11-01-2004, 07:11 PM
vmax1500's Avatar
Great numbers... my guesstimate was pretty close... only 8HP and 9lb/ft off!!!
What's up with the smoking? Could you post the details of who did what with the assembly? Thanks
Old 11-01-2004, 07:27 PM
pdd
pdd's Avatar
Sounds Great
Old 11-01-2004, 09:05 PM
Restricted User
CAT3's Avatar
max's dad, this is using the high compression ZL402 correct? And was the shortblock installled as shipped or did you, or have someone, go thru it first to check all the tolerances?
I was considering this sb, but seeing that its iron, and that no one want to release any info on internal parts I am skeptical. Besides, its not ring gapped for over 200Shots!
Old 11-02-2004, 12:58 AM
2thousand2's Avatar
poor 10-bolt!! nice #'s
Old 11-02-2004, 01:08 AM
cyphur's Avatar
very nice #'s. congrats man! just wish SLP didn't suck so bad for customer service, i might think about this motor.
Old 11-02-2004, 09:49 AM
vmax1500's Avatar
It's a shame that the 1st real review of this product is so negative... A budget 402CI Iron Block for under $4000 would have lot's of potential!
I am happy that I chose to deal with APE for my 408CI that they will be building me this winter
Old 11-02-2004, 11:29 AM
JS
JS's Avatar
The rings will seat..
Dont worry...
Quick Reply: New setup running-SLP 402, AFR, MS3
