Question about proper valvetrain geometry?
Okay guys all the tech guru's needed here. Now say I have a pair of ported LS1 heads with aftermarket valves( l'll keep the manufacturer out of this sisce noone can get a hold of him). The heads are not supposed to be milled or anything but noone knows for sure. Now we are still using the factory rockers and lifters and a typical comp cams XE grind cam, block is a LS6. Now apparantly the head porter usues a aftermarket valve that is longer or shorter-again noone knows for sure. Now in order to get the exact valvetrain geometry we can either shim the rockers or get a different length pushrod. Well we don't want to us shims so we will get the right pushrod. According to Chevy we want to bolt down the rockers to 22ft/lb's once we hit zero lash. Now on a 5.0 mustang with non-adjustable rockers, after u get zero lash you should hit 17-20ft/lb's within 1 turn. If not u can either shim or install a different length pushrod. Now my question is does this theory also apply to the LS1/LS6 engines? Another thing i did notice is that if a put a straight edge along all the valve tips there is a difference in height between the intake and the exhaust valves-say about .060. So my friends how do i check for proper lifter preload and get perfect vlavetrain geometry-I hope this question made some sense-thank you!
Some engine builders say the correct lifter preload is 3/4 turns till tight, past the point where pushrod cannot be spun between fingers. This can be corrected with different length pushrods.The factory adjustment is 1 1/2 turns until tight.
The geometry question is one I have not given much thought on. COMPCAMS, CRANE etc. can help you with setting your geometry correctly while obtaining correct preload.
Do you have stock or dual springs? When you say you can't get a hold of the porter do you mean Jay? If it is Jay I know on my heads he suggested 7.350's.
I think he uses a longer valve for the 977 or 978 springs.
