Mostly Stock Cars w/ Converters: INSIDE
Sold The Fun Stuff :(
For those with mildly modded cars (intake and exhaust work and other small things, no cams or spray or anything like that), I was curious what type of 60' times your cutting, which converter you're using, and what tires you're using. Thanks for any input on this one. I'm just trying to get a ballpark figure around what I should be doing at the track.
99 Trans Am
TCS 3200/2.5 stall
Stock 2.73 gearing
Race weight: stock + 300 lbs
Race tires: 275 Kumho (F), 255 BFG DR (R)
HAL QA1 shocks all around, QA1 springs (F), BMR springs (R)
283 RWHP/330 RWTQ unlocked on a Dynojet with the mods I have now
Best I've ever cut on 275 street tires was a 1.91 in very hot weather, and that was only once. Most of the time I see between 2.04-2.16 short times. With the BFGs I'm hoping to improve quite a bit on this, but I'm trying to get an idea of what to expect with my sorry stock gearing and my heavy raceweight. Anyone have any predictions?
99 Trans Am
TCS 3200/2.5 stall
Stock 2.73 gearing
With just the following mods, we cut 1.61 60's on our factory stock (117K miles)suspension:
FTRA
TS&P Lid
Hooker LTs & ORY
cutout
Vig3200
Convo Pros
M/T ET Streets (26x10.5x15) @ 20psi
3460lbs vehicle weight
everything else is factory stock
FTRA
TS&P Lid
Hooker LTs & ORY
cutout
Vig3200
Convo Pros
best i did yesterday was 1.68, lifting the left front
97 ta
obdi converion (pcmforless tune)
as&m headers, random tech y-pipe, corsa catback
3.73 gear
vig 3200 converter
ls1 driveshaft
bmr lower control arms, relocation brackets
hotchkis subframes
removed front swaybar
i ran on 26x11.5 et streets at 19 psi with skinnys on the front
ran a new best of 12.98@106.4
97 ta
3.73 gear
vig 3200 converter
ls1 driveshaft
hotchkis subframes
i did a 1.77 on BFG's with 2:73's and just a lid and exhaust, raceweight was 3472 and 285RWHP
my bad i didnt realize you were looking for people with converters, that was on stock converter
my biggest mods besides my vig3200 are lid, coutout, tuning and 3.42's. no headers, bone stock suspension. My best street tire 60' was 1.805. However its very inconsistant, it could be 2.0 next run. I cannot stall it up with street tires and I usually leave the line at part throttle an roll into it. Yesterday i was in the mid 1.7 60's on nittos leaving off of 1500rpm. When I tried stalling to 2500rpm it blew the nittos away on the launch so I think its capable of a high 1.6 with ET streets.
I have spun my way to a 1.64 on drag radials. Last time to the track i tried my Now dead E/T streets(26/11.5/16) i could only pull 1.74's,spun too much.
SS4000
Hooker LT's ORY,Borla
Eibach Prokit
3636 raceweight
LID
GMAS
BMR : STB,SFC,LCA relocation brackets(bolt-on)
Stock chrome ZR1's
Built trans
Everything else is stock.
Dave
SS4000
Eibach Prokit
3636 raceweight
LID
GMAS
Stock chrome ZR1's
Built trans
Dave
Yank ST3500 Stall
BFGs
1.64 60' with traction loss on launch. Very consistant but I am having trouble getting traction. I am sure that with ET streets and a good burnout I will be 1.5x
BFGs
Wow, those first two posts were discouraging. LoL, some great 60' times guys. I figure I normally pull a 2.0 on street tires and have pulled a 1.91 once, so hopefully with these stickier tires, and my QA1 setup I can get well into the 1.8 range, maybe a high 1.7 (I dont hold much hope though with only a 3200 stall and my high raceweight).
Two of my friends just picked up some of the new MT Drag Radials and had great results with them. Everyone I have talked to who has these tires can't stop raving about them. My friend's 03 Cobra was running 2.1/2.0 on street tires, he's running consisitent low 1.8's on these tires. My other friend switched from the BFG Drag radials on his Grand National and is running low 1.6's on these tires, 1.62 is his best so far. He has run a best of 1.59 on MT slicks. These tires seem to stick great. I'm seriously thinking of ditching my Nitto's next year and getting a set of these.
lol
my race weight is 3700 lbs with me in the car. put some sticky tires under it, and just play with different rpm's for the launch and you'll find the sweet spot for it and be happy we you get the slip
Restricted User
When I was stock...
1.60 60" 12.02@111
'01 Trans Am
Ar Lid
Headers & Catback
Under Drive Pulley
Vig 3200
Stock 3.23 gearing
Race weight: stock
Race tires: Et Streets
1.60 60" 12.02@111
'01 Trans Am
Ar Lid
Headers & Catback
Under Drive Pulley
Vig 3200
Stock 3.23 gearing
Race weight: stock
