this will be interesting
I just got my QTP headers and TSP X pipe installed last night. Now what i am trying to figure out is how i am going to get my X pipe/true duals to run all the way to my cat-back. Am i going to haft to order some custom bent pipes in order to do this or what? Also i don't want to have mufflers that dump out right before the rear axel so that idea is out. Thanks for any responses gang
Awesome, take as many as possible and post up! I've been looking for more "over the axle setup" pictures and haven't had any luck to speak of. Are you having it done at Speed Inc or a local exhaust shop, or what? Details? Thanks!
Also i was hoping to run a 3" pipe all the way to a cat-back. Will this work? Also explain how it will. I don't think ive ever seen a cat-back that can collect from 2 seperate pipes. thanks
if you want to run 2 separate pipes,you'll most definitely need 2 mufflers.you could just put 2 "dummy" tailpipes that make it LOOK like you have a muffler.BUT you'll be able to tell that you dont have a muffler,since normally you can see it.i dont know you got me stumped...
Here is your answer
http://ls1speed.com/catagory.cfm?catagory=exhaust
Custom True Dual Exhaust
Inhouse custom true dual exhaust setups available built from any header on back. 3" off the header into a 3" X Pipe and out 2.5" into 2.5" ATR Pitbull Stainless mufflers. Round or oval tips available. No suspension modifications required.
$1,199.99
Look about half way down on the link for a pic.
$1,199.99
Originally Posted by mnc2886
I'm doing 3 inch over my axles and posting pics of it on Friday.
Originally Posted by JZ'sTA
Here is your answer
$1,199.99
$1,199.99
