Heads milled .015 with G5X3
Old 11-02-2004, 12:30 PM
JoeT/A's Avatar
Default Heads milled .015 with G5X3
I am looking at a set of 5.3 heads but i just found out that they are milled .015. I was wondering if the X3 will clear even with this small amount of milling.
Old 11-02-2004, 12:49 PM
jermstyle's Avatar
The X3 will not fit with un-milled heads. You need new pistons or a fly cut to run that cam 'safely'.
LG said to fly cut .060 with un-milled heads, so you would need .075 to clear!
Old 11-02-2004, 12:51 PM
JoeT/A's Avatar
Are you saying that even unmilled 5.3 heads you would have to flycut?
Old 11-02-2004, 01:01 PM
JoeT/A's Avatar
I am running the X3 on my stock heads now with no problems.
Old 11-02-2004, 01:11 PM
jermstyle's Avatar
Just sharing what LG said... And yes, I was told to fly cut .060 with un-milled 5.3 heads.
Old 11-02-2004, 01:22 PM
xfactor_pitbulls's Avatar
I have several people comment that the X3 would clear on a 114 but be close on a 112. That was with 853, 241 castings. Being that the 5.3 head has more compression it also has a lower overal deck thickness.
Gurus?
Brandon
Old 11-02-2004, 01:23 PM
nspr8td lt1's Avatar
you need to fly cut on the 112, not the 114.
Old 11-02-2004, 02:08 PM
JoeT/A's Avatar
Mines on a 114 LSA
Old 11-02-2004, 03:16 PM
Can you not read?
Brandon
Old 11-02-2004, 09:04 PM
JoeT/A's Avatar
Can you not read?
Brandon
That still don't answer my original question, can you read?
Old 11-03-2004, 01:00 AM
v8-7's Avatar
he also has 5.3 heads!! not 5.7s ... I have the exact setup, x3, TEA stg2 5.3 heads milled .015 and am currently trying to figure out how much to dish my custom forged pistons...
Old 11-03-2004, 06:38 AM
DAPSUPRSLO's Avatar
I can't imagine how reducing the lsa by two degrees would cause a 60 thousanths reduction in piston to valve clearance. Maybe I am just missing something.
Old 11-03-2004, 07:05 AM
waiz1's Avatar
I believe the 5.3's should have same clearance if unmilled, the problem come once you get into larger valves I believe. I think you would probably have to flycut, but no one will be able to give you a definate answer, youll just have to check and see if thats what you want to run. Whatever you do, dont just hope that it works cause someone said it would.
Old 11-03-2004, 02:04 PM
Louis's Avatar
What valve size?
Old 11-03-2004, 02:08 PM
Scalpel's Avatar
Louis will get you the info you need, Joe.
If I were you I'd get a custom set of 5.3 S2s from TEA. Trust me
Old 11-03-2004, 02:40 PM
Joe, I was referring to the guy before you that said you have to fly cut 112 instead of 114. I tried to do that math with equations on here, but couldnt get an answer I would be confident enough passing on, due to the fact it is so close.
Good luck
Brandon
Old 11-03-2004, 06:16 PM
under_construction's Avatar
My 5.3's are milled 0.030, and it took a pretty deep flycut - 080 or more to clear my G5X3 on 112 lsa with 2.04 valves. The big problem is the larger valve size, especially on a 112 lsa. Stock size valves on a 114 lsa are supposed to clear, any other combo requires a flycut. I'd call Lou to be sure how much.
Old 11-03-2004, 08:01 PM
YsoFast's Avatar
under_construction,
What problems would cutting the pistions that much cause? The reason I ask is because I have the same heads cut .025. I have a FM13 114+4 going in and if the shop tells me they have to cut for it I think I am going to step up to a G5X3 112 and have them cut a little more.
Old 11-03-2004, 10:32 PM
JoeT/A's Avatar
Yeah that's the route it looks like it will be. Looks like spring might be fune now.
Old 11-04-2004, 01:05 AM
v8-7's Avatar
O yah, i have oversized valves too
Quick Reply: Heads milled .015 with G5X3
