18X10.5 Y2K vette wheels with 335's?
Old 11-03-2004, 12:45 PM
777's Avatar
Default 18X10.5 Y2K vette wheels with 335's?
i'm wanting to run a y2k vette wheel in the back...i found some that are 18X10.5 replicas...i could widen them to whatever need be i guess....so i'm wondering if it can be done...how hard would it be...what size spacing would i need to run...if it won't work without a huge spacer i guess i'll pass...i don't want it to break on me...i'll have ~425rwhp...and possibly later a lot more if i throw a supercharger on it...i just want to know if it will hold up...i really like the y2k style and i can get these rims for about 1200$ for all four...plus widening...if there are other rims that i could get for the same and look similar or better let me know...just wanting something wide, nice, and fairly inexpensive to replace my stock 16" wheels
Old 11-03-2004, 12:59 PM
xfactor_pitbulls's Avatar
To be completely honest why would you want a tire that big? It is going to sap horses, it cost a ton more to replace, the actual fitment under an F-Body as opposed to a Vette is crap. Why not just go with a 315mm drag on your wheels. That way you dont have to widen them. A drag radial in that size is going to hook, period.
Brandon
Old 11-03-2004, 01:18 PM
777's Avatar
you think i could fit a 315 on the 10.5 wheel....i guess i could try those new nittos...the 305's? thanks for the feedback...i was really debating this...but after looking at my friends boss's new viper...i couldn't help but wonder
Old 11-03-2004, 08:05 PM
02blackws679ta's Avatar
if youre set on 18's i would say just get 305s
you would be doing a SHITLOAD of work to get a 12-13''x18'' wheel to fit on your car
not even close to being worth it IMO...if youre worried about hooking, do as has already been said and get a decent sized drag radial
Old 11-04-2004, 09:01 AM
Xsta Z 28's Avatar
The biggest problem is the offset, usually they are around 56 mm and it places the wheel fairly deep into the wheel well. Wider tires would require more BFH or a spacer.
Old 11-04-2004, 09:15 AM
5POINT7's Avatar
Yup, what ^^he said. An offset that high will tuck your wheel in so much, you'll need to hammer the fenderwall in or get a spacer.
For reference: My 17x11 36mm offset wheels (sticks out a lot farther than 10.5 56mm's) req'd. the BFH mod.
Old 11-07-2004, 10:49 PM
777's Avatar
yes...i'm completly confused on the wheels i want...i know i like the c5 y2k's but there just seems to be too much problems with them...i.e. bad offsets...you pretty much have to use spacers to make them look right...i don't wanna spend a lot on wheels but i want some that look nice too...i may end up widening the stock ws6 wheels...who knows
Quick Reply: 18X10.5 Y2K vette wheels with 335's?
