IFR question and bigger injectors
Old 11-03-2004, 07:58 PM
HumpinSS's Avatar
Default IFR question and bigger injectors
Why cant we multiply the IFR table by the percentage the injectors have gotten bigger
Ie 30/26=14% bigger
Old 11-03-2004, 08:01 PM
slow's Avatar
sorta, but remember those 26's (stock) are at 4 bar, and the 30's are most likely rated at a 3 bar setup.
Ryan
Old 11-03-2004, 08:16 PM
HumpinSS's Avatar
Ok that makes sense i forgot about the. So what if all things were equal. Would that work?
Actually a 30 psi injector at 4 bar is equivalent to 34.64 lbs injectors
Old 11-03-2004, 08:34 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
If all things are equal, just convert lb/hr into g/sec and voila - you'll have the exact IFR you need.
Old 11-03-2004, 11:05 PM
GrannySShifting's Avatar
you cna Dirk, when you get the rated pressure the same like they said
Old 11-04-2004, 06:43 AM
HumpinSS's Avatar
Thanks I was wondering because I see posts in here from time to time asking for the OFR tables for X injector. I thought there was a harder way to go about it besides what i posted above
