Received clear corners!
I just got my clear corners in the mail and when I took em out of the box I held it next to my original corners and my clear corners looked a lot larger when I compared em. why is that? please help. Let me know if I have the wrong ones
Originally Posted by superchannelkev
you should have the right ones.. a little bit is behind your bumper.. but not too much.. if you ordered a set for a 93+ you'll be fine..
Originally Posted by Chad01Z28
Take the headlight out. Going from underneath is a real PITA.
2nd that all the way you'll have it done in 30 mins.. (1st time) Make sure to seal the corners first!!!
Originally Posted by SSmoked99
how do I seal em? With what? Where can I get it?
I've found removing the headlight assembly to work best, this might help https://ls1tech.com/forums/showthrea...+CLEAR+CORNERS .
Al
Al
