Raising Tq curve - Cam choice?
Old 11-04-2004, 07:54 AM
Boosted LS1's Avatar
Default Raising Tq curve - Cam choice?
I've been reading some of the cam threads and am looking to raise the peak torque to higher up the rpm range on a stock ls1 with ls6 intake. Thus far the cams I've used have increased the torque everywhere but not really moved it higher. The car is using stock redline and is lightweight so makes to much smoke on initial launch. I'll get some more bhp as well. Have you guys any suggestions? Also, who makes these cams, MS3, G5X3,Trex. I need some specs for them. Thanks.
Old 11-04-2004, 08:34 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
MS3 (Texas Speed & Performance)
G5X3 (LG Motorosports)
TRex (Thunder Racing)
All 3 of those cams will move the tq peak up high.
I have a TSP 231/237 cam and it peaks at 5000 rpm.
Your engine's rev limiter must be raised to about 6900 rpms.
Old 11-04-2004, 09:21 AM
Cstraub's Avatar
Mike,
In simple terms, increasing duration will do what you want. As a side note though, the hyd roller is not designed for "high" rpm operation. OEM's brought it out to make low end power. The mass of the lifter itself and the physics of the hyd. valving limit this. You may want to fool with tranny gearing to improve 60fts and use the power you are making now.
Chris
Old 11-04-2004, 10:41 AM
94form2000z's Avatar
I agree with the duration effecting Torque and HP peak normally.
Old 11-04-2004, 11:34 AM
Thanks for the info. I can run grinds through the pc but that's a bit 'hit & miss'. There's nothing better then getting advice first hand and seeing what you guys like. I want to stick with the stock valvetrain and rpm's on this engine. What sort of engine power/torque are those cams making in a fairly stock ls1?
Old 11-04-2004, 11:40 AM
DietCoke's Avatar
You will not be able to use stock valvetrain. You must upgrade valvesprings.
Old 11-04-2004, 11:55 AM
I use the comp 'blues'. Thanks for the mention though.
Old 11-04-2004, 12:55 PM
!LS1 11 Second Club
Using Comp 918's the TSP 231/237 is about as big as you can go.
I hope you're not boosting with these large split, low lsa cams. These are definately not forced induction cams.
As for having too much tq down low, that's what proper tire, gear and suspension setup is for.
Old 11-04-2004, 03:13 PM
I know exactly what you mean. These guys don't want to rebuild the car, just shift the tq a bit further up It's n/a. Cheers dude
Old 11-05-2004, 10:52 AM
Has anybody used the GM performance camshaft that was tested in Hot Rod magazine with a carbed inlet assembly? I think they claimed a very high power figure for it, over 500 hp which I thought was a bit unrealistic.
Old 11-05-2004, 11:07 AM
!LS1 11 Second Club
Gmpp Cams
Check out the high rpm range of the Cup cam. Insane.
