214/220 .600/.523 115
Old 11-04-2004, 05:32 PM
JBGRAYTA's Avatar
Default 214/220 .600/.523 115
The old man cam. I haven't found much info on this cam. I saw it on the TSP site saying no tuning required. Well, I just wanted to pop a mild cam in for now since I am slowly building up the drivetrain for a future project next summer(not quite sure yet, but something monstrous). I just don't want to dole out the money for the entire cam set, install cost, tuning, etc... when I'll probably be ripping it out in the near future. Any other cam recommended? My mods are in sig. Thnx
Old 11-04-2004, 06:17 PM
LS1 Tech Administrator
Patrick G's Avatar
Awesome cam. Makes power everywhere, but runs and sounds like stock. I had one in my '98 SS. I made over 400rwhp with ported heads and lots of bolt ons. Pulls some pretty high rpm too because of the LSA in retarded ICL. (it's 115 LSA and 117 ICL).
I may put another one in my new Trans Am. I love that cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 11-04-2004, 06:47 PM
equandt's Avatar
LPE GT2-3 is a pop in mild cam. You might research that cam.
Old 11-05-2004, 11:12 PM
StickSS's Avatar
Hi Patrick: If your out there a have a few questions for you about your old car with the Old Man Cam and ported heads.
You made over 400 Rwhp was this car was it Auto or stick? Was it the stock rear gear ratio? Did you have to get the car tuned or was it on a stock tune? Can you list the other bolt on parts you used with this combo? Was it thru an open exhaust or a closed exhaust? The reason I ask is that I like this combo on a street motor it must make some crazy torque down low and mid range. I wounder what that little cam would do with AFR 205's? Thanks for any help.
Old 11-06-2004, 08:32 AM
68birdls1's Avatar
if your just gonna throw one if for now and then change in the summer, just cut out the middle man and save your money for your summer project! believe me it is always better to have some extra money just incase something goes wrong. i would say hold off until you are ready to do your somehting "monstrous"
Old 11-07-2004, 11:32 AM
Patrick G's Avatar
Check this out: http://www.converter.cc/98_SS_Convertible.htm
You can check out the bolt-ons I had and setup of the car. The car had 5 different cams in it over its lifetime.
Fast ETs were done with TR230/224 111LSA cam.
Last cam I had in it was the 214/220 115LSA Old Man Cam. Made stupid power on the street with ported heads. Great fun on nitrous as well.
__________________
Old 11-07-2004, 02:22 PM
Sport Side's Avatar
What's the reasoning behind the specs?
More lift on the intake,
More duration on the exhaust.
The intake side has more duration once the valves open up a bit more?
At .200, what sorta split are we looking at?
Be interesting if it were ground having a tighter lsa.
Old 11-07-2004, 04:53 PM
StickSS's Avatar
Thanks Patrick for the further info on your old setup. This looks like a very good combo for a street motor. I would really like to see some one try the AFR 205 heads with this cam. The small port high velocity design would make and insane amount of torque.
Old 11-08-2004, 06:25 AM
Irish Whiskey's Avatar
Who makes the "old man cam?"
Old 11-08-2004, 08:07 AM
Bearcat Steve's Avatar
Texas Speed & Performance - they are a sponsor and their add can be found on the right ------------>
Old 11-08-2004, 08:55 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
No, the OMC is a Thunder Racing cam...
Its not from Texas Speed....
Quick Reply: 214/220 .600/.523 115
