neutral safety switch question
Ive got a a-4 car that i recently put a TH400 in and a aftermarket shifter ,
just wondering if any of you guys had done this and what needs to be done with the wire's ( 6 wire harness ) to trick the PCM into thinknig its in Park or neutral to start
thank you ...
thank you ...
thank you ...
thank you ...
Originally Posted by V6 Bird
Theres a black box on the side of the A4 shifter...it must be all the way up on one end or the other for the car to start. Then you slide it into P to get a reading with your wire prob for the nuetral side. Then you slide it one click back for reverse and probe it for those wires...But you do need to leave the black box in P or the car wont start at all in any selection....At least with the probing that we found after an hour or so...Call my cell, if you need some help still. It wont bite!
I do have a wiring diagram to search out the wires in the arch shaped wire loom/slide you are talking about . Once I hook up the neutral safety switch wire to the new shifter I can remove the arch thing. Right?
Ken
