My SES light is on.
My SES light is on.
MY friend installed LT Pacesetter headers,and Ypipe on my Car,and it rips.
(It also feels good to) But my SES light came on.Doe's anybody know what is up with this. Can this be harmful to my Car?
Everbody would be just shooting in the dark about this so I would suggest if you don't have an OBII system tester or AutoTap you take it to someplace like AutoZone and have them test it for free. In the mean time you could look for loose wires/wires touching the headers, vacum leaks. Good luck and let us know what you find out.
Al
Al
hi guy I'am nocturnal SS friend that install the headers for him.I went to auto zone and i forget the exact code number but it said bank 1 heater circuit insufficient or something like that.so they erase the code and I went home double check all the O2's connections again.and it came on again the next day or so.so is it the o2's or the o2's ext .thank guy for any help.
could take a volt meter and at the conector of the harness from the the car
put the meter leads on the two brown wires, should be C and D pins i think.
and turn the ign. on, and masure the voltage, should be about 12 volts
if less than 11 volts check the ext. wires or the sensor fuse.
if there is about 12 volts than it is the O2 sensors.
hope that helps.
