Any AFR results on A4 cars?
Old 11-05-2004, 07:57 AM
offaxis's Avatar
Default Any AFR results on A4 cars?
It seems like knowbody with a A4 car has bought these heads. If anyone has some a4 dyno results with afr heads please post them up. I am interested in these but It seems like only m6 cars have posted numbers with these.
Thanks
Old 11-05-2004, 11:09 AM
JS
JS's Avatar
Get hand finished if u buyem....
Old 11-05-2004, 11:21 AM
MYBLKSS's Avatar
I can't post results but my A4 with AFR's 205's put down 375 HP and 350tq. Seems low but my cars has always dynoed low. What seemed unusual to me was my torque. The numbers above are unlocked, but the car did run an 11.90 so I am happy. I still have stock compression (66cc w/stock gasket), and the TR224/.561
Old 11-05-2004, 12:48 PM
offaxis's Avatar
Hey man
Those times are pretty good. With a good 60 ft you will be movin out. With your setup low 1.6X 60`s should be no problem on a nittos
Old 11-05-2004, 05:12 PM
xfactor_pitbulls's Avatar
Man dude something is wrong with your ride. Those numbers are way low. Especially the torque. As far as the time goes I know a few guys that have 370ish whp in A4 cars running 11.7-11.8. I would be pissed after a purchase like the AFR heads and only seeing that. No offense intended.
Brandon
Old 11-06-2004, 08:46 AM
TTPMatt's Avatar
We did a Vette with 3.90 gears. Kooks 1 3/4" through cats, Mez Electric WP, Stock LS6 Intake, Stock T/B, AFR 205cc, TTP 224/228 Comp XE-R 114lsa in an auto. The car made 301rwhp when it had a m6 in it, then did the a4 swap added the heads/cam and made 411rwhp. This is all done with about 14 deg of timing due to a d/p nitrous setup. So he gained 110rwhp, and went from m6 to a4 at the same time.
Old 11-06-2004, 08:50 AM
offaxis's Avatar
Nice gains!!
Old 11-06-2004, 11:33 AM
Worm's Avatar
350rwtq unlocked? Sounds like your converter is hosed.
Old 11-06-2004, 10:39 PM
Spellbound's Avatar
My girlfriend has them on her car, 2002 Z/28 A4, with a Stealth II, no dyno numbers yet. Sotp doesnt feel any different than the Absolute stage II's she had on prior to the AFR's.
Old 11-09-2004, 11:29 AM
MYBLKSS's Avatar
I have no idea why the car dyno's low. Somtime over the winter I am going to do a leak down test just to make sure everything is OK. I am also going back to my yank, I really never liked my Vig.
Old 11-09-2004, 05:42 PM
6 Second Club Moderator
LASTLS1's Avatar
Why is that?
Old 11-09-2004, 05:58 PM
Sn8ke_Eater's Avatar
I got the pp 5.3lL heads stg2 milled 0.05 for high compression and a 226/230- 590/590-114lobe and bolt-ons and i dynoed 405hp-395trq converter unlocked.
Old 11-10-2004, 10:08 AM
HumpinSS's Avatar
May want to take a look at this thread
https://ls1tech.com/forums/showpost....2&postcount=23
Old 11-10-2004, 10:20 AM
offaxis's Avatar
Good numbers but your tq looks low with an unlocked converter. BTW what does your post have to do with AFR heads on a A4?
