Fueling & Injection - H/C Install, which injectors to upgrade to?
1BadMoFo
11-06-2004, 07:59 AM
I currently have the usual air in/air out stuff...K&N FIPK, P/P TB, LS6 intake, LT Headers and TSP True duals...
I've already bought but not installed APE Ported/Coated Oil pump, MTI G1 Cam, MTI S2E Heads, rods, rocker arms...will soon get a pulley and injectors...
Because I have a 2000 I know I need to replace the 26.4lb injectors, but can I stay with the 28.8 lbs ($50) or do I need to look at some in the low 30 lb range for quite a bit more $$?
Scott
RedHardSupra
11-06-2004, 11:13 AM
I got some SVO 30# (which works at about 36# at GM fuel pressure) if you're interested. according to my calculations, you should be at about 80% duty cycle around 470rwhp, which is a very nice safe setting for even a big head/cam combo and maybe even a little spray on top of it.
1BadMoFo
11-06-2004, 11:16 AM
are you saying they are for sale?
Worm
11-06-2004, 11:44 AM
I think stangstore.com has the SVO 30# (36lb on our 61psi system) for sale for $229.95 if I remember right. Just a heads up. If you want more there is a GP on some 42lbers in the Gp section for $299.99.
Worm
11-06-2004, 11:45 AM
Correction $189.95
http://www.stangstore.com/Merchant3/merchant.mv?Screen=CTGY&Store_Code=S&Category_Code=50INTAKE
Theres the link. I hope its ok for my to post it. Just trying to help an LS1 brother out. TSP wants like 300 for the same exact injectors (The part no is listed on the site).
1BadMoFo
11-14-2004, 08:03 PM
I've been holding out to get more info, but so far these are looking pretty good...too bad there is such a jump in price for the 28.8's to these 30's...
1BadMoFo
11-21-2004, 08:28 AM
well...no clear answers, I've been told 28.8, 30, and 36...right now if I was to buy some it'd be the 32# from Racetronix, on sale right now...
