2nd only-is tranny blown?
While driving easy today tranny started acting up. At first it would not disengage at a stop and stall motor (like a standard if you didn't step on clutch) . At first I thought the converter lockup was not dis-engaging. I parked car , and when I started to drive it seemed like converter was slipping (have Midwest 3000/2.0 str) . 2 miles later car would hardly move except in 2nd with no shifting. Checked fluid- OK. This is an 02 Z-28 with 11,000 miles. Mods; D1-SC ,Transgo shift kit, Midwest verter. Did I kill my tranny ? Thanks
Any SES lights?
Try disconnecting the battery for a minute and then going for a drive, if it doesn't work I would guess the tranny needs to be rebuilt, I am sure the D1-SC isn't helping
Your transmission could be stuck in fourth and it still wouldn't stall at a stop. The only way you would have a stall condition is if the converter was locked up.
You said you have reverse. Does it feel like the foward gears?
The verdict is in the tranny puked. I am no expert but metal shavings in the pan tell the story. Took the tranny out this morning. It's hard to believe I watched the odometer turn 11,000 miles as I drove my crippled car home. Now it's time to spend money in RIGHT direction and get a tranny that can hold up. I want to stay A4 , any ideas on a built tranny that can take it ? Thanks for the input.
A 4-speed automatic that can be expected to hold up behind your motor is the 4L80-E. I don't have much information on the swap of an 80 into an F-Body, but it has been discussed here and done before. You will find that many people opt to install a manual reverse-pattern valve body so that it shifts manually. This is not necessary - the computer can shift it with the right programming and harness adapter. Unfortunately you will have to buy a new converter and fabricate a crossmember and install an aftermarket torque arm that bolts to the chassis instead of the tailshaft housing, or perhaps a custom modified tailshaft housing for the 80, so this is not a simple project by any means. The result of all the work WILL BE a 4-speed auto that you never have to think about. The added weight and narrower gear ratio range are trade-offs well worth the increase in powerhandling and shift precision. The close ratios make the 1-2 shift a lot better than the 60 can provide. I know of nobody unhappy with their 4L80-E swap.
Good Luck.
4l80
Thanks James B, can a built 4l80e w/converter be had for $3000.00 ? Anyone ? Thanks again.
