Fueling & Injection - whats a good large low Z injector?
parish8
11-06-2004, 10:26 PM
is there a prefered brand of injector in the 85-100lb range?
JZ 97 SS 1500
11-07-2004, 09:57 AM
Seiman Deka, nothing else...
F8L Z71
11-07-2004, 10:13 AM
You're a nutcase Jim!!!!
LOL
parish8
11-09-2004, 08:24 PM
another guy i know is telling me delphi. some kind of consensus would be nice.
is a cone or pencil stream better?
Pro Stock John
11-09-2004, 09:35 PM
8 second guys told me to get Siemens, that's what I have.
LIL SS
11-09-2004, 09:44 PM
I have always ben told a cone is better.
parish8
11-10-2004, 12:23 AM
thats 2 votes for Siemens, guess i will go with Siemens.
thanks for the help.
1dirtyZ
11-10-2004, 01:07 AM
try the RC engineering 75 lbs hr. ones if you uare looking for low impedance injectors.
Rick@Synergy
11-10-2004, 10:24 AM
LOL
He's not a nutcase. :D I dont blame him for needing them. Ran ot of fuel last night while tuning, either my pump didnt support the demand or the injectors went. Either way I think I hurt something. Anyone know of a good dual intank pump out there?
Who has a good set of 60lb injectors?
Rick
y2khawk
11-10-2004, 10:29 AM
My 96's were rochester/delphi style, my 160's are Bosch.
I got the 96's dialed in pretty well, they idled very well. Even w/ the base pressure up to 60 (flowing about 100 lb/hr then).
The 160's are still a work in progress ;) But they work.
parish8
11-10-2004, 04:19 PM
Rick
i will likly have some 57lb(@43.5psi) units for sale in a few weeks.
parish8
11-10-2004, 04:27 PM
are these the injectors you ran? http://www.racetronix.com/17113744FM.html
got another question for ya too. i am looking ahead to a set up similur to yours, posiably twin t66's or maybe a thumper. wouldn't the 95's have fed your twin t66's? why the 160's?
is my math messed up? firgure twin 66's = 1500hp max
95lb/hr injectors at 60psi = 100+lb/hr ea, so 800+lb/hr of fuel and a .5BSFC ends up at 1600+hp worth of fuel.
even at 43.5psi the 160's seem prety large? you going larger turbos some day? :devil: twin 76's? :D
y2khawk
11-10-2004, 04:47 PM
yes those are the 96's
Your forgetting RPM in your calc's, not to mention BSFC is closer to .6
At 6k RPM you get 20ms to get the fuel in, but at 8k RPM you only get 15ms. Total flow is not the issue, it's window of opportunity :)
bigger turbo's are already on the way :devil:
parish8
11-10-2004, 04:59 PM
thanks for the info, t76's?
the calculators i see dont use rpm for calculating how much hp an injector will support. i wonder if BSFC goes up with rpm? my BSFC calcualtes out to .53 right now.
Rick@Synergy
11-10-2004, 05:41 PM
I just might need those from you. Let me know when you are ready to sell them. Also, did you get the valves I sent?
Rick
y2khawk
11-10-2004, 06:18 PM
RPM doesn't figure in to supported HP exactly, but you can't run them past 100% duty cycle. And that depends on RPM.
MIGHTYMOUSE
11-10-2004, 06:30 PM
i currently have delphi 96's after running the mototron 60 highz's to 100% on the last dyno.
a little bit of work to the offset table has brought the 96's to a nice place at 1.3ms and 0% duty cycle at idle and i daily drive on them
