P0121 In-Range Operating Throttle Position Sensor circuit failure
I've got a '98 Z28 M6 and I picked it up from the shop after a new tune and install of LS6 intake (w/o EGR) and a ported throttle body. On the way home, the SES light came on. I took it to Autozone that night, scanned and two codes came up.
P0121 In-Range Operating Throttle Position Sensor circuit failure.
P0404 Exhaust Gas Recirculation circuit rang/performance
I could care less about the EGR code .. I think the tuner just neglected to delete EGR stuff from my computer.
But the TPS one worries me a bit. The ported throttle body I was given from an online shop had a slightly larger pedal than my original '98 throttle body. Does this have to be accounted for through tuning or should I not even be using a throttle-body with a larger pedal? I've also read that the computer simply just throws this code after a cam swap and tune, which I had done before my recent trip to the shop, and has to "learn" the tune. After the initial install of my cam and tune I did get an SES light, but it disappeared before I got a chance to scan it .. and I'm thinking it may have been the same P0121 code.
Your thoughts?
Thanks,
Sean
Your thoughts?
Thanks,
Sean
