700r4?
Old 11-08-2004, 06:35 PM
My84Z's Avatar
Default 700r4?
what would I need to get a 700r4 in my car? I have one and was wondering what it would take to make work? Thanks John
Old 11-08-2004, 06:49 PM
1QWIKZ's Avatar
i thought a 700r4 was the same as a 4l60? just not electronic though?
Old 11-08-2004, 06:56 PM
My84Z's Avatar
If it is that would be awesome cause I know painless makes a wireing kit for the 700 so i wouldn't need to use a computer.
Old 11-09-2004, 11:10 AM
Bad30th's Avatar
I'd think you would need to fab up some kind of kickdown cable setup from the throttle linkage, I think the 700R4 uses a kickdown cable setup for WOT downshifts. (I remember having to adjust it several cars ago on my 88 IROC).
...or you could just install a fully manual valve body and not worry about kickdown.
I believe they are "mechanically" the same transmission for the most part though, 4L60E being the electronically controlled version (lockup, line pressure, etc)... I'm pretty sure the 700R4 is vacuum referenced.
Not sure about converter/flywheel.
Hopefully someone more knowledgable will chime in.
Good luck !
Bad30th
Old 11-10-2004, 04:12 AM
Z1500's Avatar
If you get the right year combination you can get a completely non electric one. I have one with mechanical speedo, non lockup 2400rpm stall and cable kick down for a carb. I had it on my Nova before I put in a 6-spd. I'm selling it if you want one but it's in AZ and I bet shipping would be a bitch. Has about 10,000 on a full HO rebuild. $600
Kevin
Old 11-10-2004, 11:54 AM
93LS1RX7's Avatar
Try these guys I used them and it works great
non-sponsor.com
Old 11-17-2007, 11:40 AM
946spdz's Avatar
you dont want a 700r4 they are junk my buddy put one in his monte and it was a rebuilt one he spent 600 to rebuild it and it blew up they arnt ment to handle alot of power put a turbo 350 or a turbo 400 in it will last no matter how much power there is
