How Much RWHP Will You Lose?
Like the title says how much rwhp will you lose through a Vig 3,200 converter or as in any converter in that matter? Also with the higher the stall is it the more hp you lose?
Thanks Dan
Thanks Dan
I believe that the STR has a bigger effect on the power loss than the stall speed. Somebody correct me if I am wrong........
Who cares if you technically lose power when you can take a half second off your time though?
