LS1 Edit
Old 11-09-2004, 06:32 PM
chris-camaro-ss's Avatar
Default LS1 Edit
Heres the deal : Me and 2 of my friends want to get ls1 edit. Were gonna buy one and add vin #'s. We figured it out to be 250 each. Now a dyno tune around here cost 450 alone. What I would like to know is how complicated is this program ? Because this winter i plan on headers, gears , torque converter and maybe a hot cam. Would it be a good idea to get an AEM Wideban 02 gauge ? I could also get the afr froma dyno (3 pulls within an hour for 100$). Any ideas ?
Old 11-09-2004, 06:57 PM
BLK02Z06's Avatar
Well, first you may want to post this in the tuning section... You may get a better response... Personally I would get it tuned by the shop, they are experienced and usually will do free re-tunes with new mods. Plus you get the dyno time at no additional charge.. But good luck anyways!!
Old 11-10-2004, 01:34 PM
If me and my friends wanted to get this dynojet wideband commander do u think we could each buy their gauge and use the 1 program on the computer ? ?
Old 11-10-2004, 01:51 PM
HumpinSS's Avatar
If you and your friend have the same year why not get HPTuners/EFIlive and call it a day.
BTW the dynojet WB can be hooked up to either cable and the data merged into the data stream comming from the PCM. Edit doesnt offer this option and you will have to manually look at the WB to make any corrections
Old 11-10-2004, 02:43 PM
Bill Bowling's Avatar
Check this out before you buy.
https://ls1tech.com/forums/showthrea...hreadid=236601
Looks good to me. Anything is better than Edit.
Bill
