231/237 owners come in
i was just wondering where you guys made peak power(rpm) on the dyno..mine topped off at 6600..isnt that a bit low? and does 13.3 seem a bit low for a/f at peak power?
Mine made max hp is 6600rpm and stayed constant till 68/6900ishrpm then lost about 10hp per 100 rpm.
My max power was 421/385 w/ LS6 intake, PPLS6 style heads, LG Pro Longtubes w/high flow cats, corsa indy catback, vararam intake, stock everything else. I also was at 100% duty cycle on my 22.4#injectors from 4500-6900.
I put some hand ported LS1 heads in place of the PP heads, added volant air bridge, 28.8 LS6 injectors, so I will let you know what it makes with the replaced stuff.
