what spark plug wires would you recomend?
Old 11-09-2004, 08:41 PM
frey51's Avatar
Default what spark plug wires would you recomend?
I am ordering my tr6 plugs tonight, and I figured since I have the ability to buy them now...I should get some new wires. But I am not sure what ones to get. I am thinking about the MSD 8.5 SuperConductor, but would like some input. I am pretty sure that I may break a stock wire or two, because they are on the stock plugs at 53K. What would you choose to go with some tr6's?
Thanks Fry
BTW, I am getting this stuff tonight, so quick repsonses would be nice, but not necessary
Old 11-09-2004, 08:44 PM
ddelallata's Avatar
Taylors are good as well as the MSDs. The stockers are good enough to begin with,so you shouldn't have any problems puting them back in.
Old 11-09-2004, 09:02 PM
frey51's Avatar
I'm just worried about breaking one, as I understand that is a good possibility. I dont want to break one and not be able to drive, as I need my car since its my current daily driver. I know that the stock wires are pretty good, but the aftermarket wires are a little more expensive than oem. I think I am going to go with msd.
Fry
Old 11-09-2004, 09:21 PM
silverZ98's Avatar
MSD's here and not a problem with them
Old 11-09-2004, 09:28 PM
2FAST4U's Avatar
Taylors here and I buy new ones every time I change motor! Just b/c I have seen so many lsx with missfires! It is a must to use that white grease for electric contacts--super super important--.
Old 11-09-2004, 09:31 PM
Z28Venom's Avatar
MSD Superconductor 8.5s here... I also will be installing NGK TR6s this weekend.
Definitely use the dielectric grease. I didn't apply it once and the car misfired like mad..
Old 11-10-2004, 04:08 AM
frey51's Avatar
I'm glad someone has recomended the dielectric grease. I have heard of people using this to get better connections, but never used it myself. Do I put it on both the plug and coil ends of the wires? or just one? And I can get that at pep boys or the like, correct?
Thanks
Fry
Old 11-10-2004, 08:29 AM
Redlinez's Avatar
I'm getting the Taylor Thundervolts. They snap on with authority and don't need heat sleeving for headers. Check out Thunder>>>>>>>>>>>>>>>
Old 11-10-2004, 10:51 AM
Z28Venom's Avatar
Thanks
Fry
Yes.. put it on the tip of the spark plug, and also on the spark plug connector for the coilpack.
Old 11-10-2004, 11:05 AM
KJ
KJ's Avatar
MSD wires would be the way to go!! We sell a large amount of these for the LS1 and I have yet to have to warranty any. Let me know if I can help you with a set!!
Old 11-10-2004, 12:40 PM
MARKSZ71's Avatar
gm no problem here
Old 11-10-2004, 05:44 PM
WILWAXU's Avatar
I've used MSD's and GMPP red replacements.
Both worked well. No issues with either.
GMPP's could be a hair longer.
