LS1 F-body work w/Trailblazer 4200?
Old 11-10-2004, 01:35 AM
Cheatin' Chad's Avatar
Default LS1 F-body work w/Trailblazer 4200?
Can a LS1 F-body converter be used on a Trailblazer with the 4200 I6 and 4l60e?
thanks.
Old 11-10-2004, 11:10 AM
CamaroCain's Avatar
I would guess NO
Old 11-10-2004, 11:43 AM
LS1Tech Sponsor
hellbents10's Avatar
Yes you can same spline as Ls-1. You can use the trailblazer converter on a Ls-1 right? that answers the question. Will it be a good choice no. It will be really tight on the i-6 with the lack of low end grunt.
Old 11-10-2004, 10:19 PM
I figured you could but wasn't sure. It's a TCI SSF 3500w/ 2.5 STR.
I think the I6 would like this converter quite a bit considering where it's making it's power
Old 11-11-2004, 09:39 AM
koolrayz's Avatar
I looked into using the trailblazer unit in my f-body. They do boltup. The converter in my ENVOY stalls at 2200 rpm
Old 11-12-2004, 01:55 PM
SSU Moderator
RyanJ's Avatar
Yes. the GM core Yank (and probably others) use IS the one used in the I5. Use it. ITs a cheap 2400-2600 stall.
