Which Exhaust
The loudmouth is a good "factory" exhuast, meaning, if you want a loud car with a little more power, then its good, however, when you start to do alot of modifications and make the car generally louder, the loudmouth is usually too loud and obnoxious. True duals is usually a better decision, but if you are planning on headers, plan on doing true duals at that same time, otherwise you might get ripped on having them made for the manifolds and then modded for the lt's
