comp cam lifters
Old 11-10-2004, 12:14 PM
zamboxl's Avatar
Default comp cam lifters
ok guys wich one do you all think is best for an ls1, with a 224, 224 cam, their pro magnum lifters or their high energy lifters???
Old 11-10-2004, 12:24 PM
Bo White's Avatar
There is only 10-15 bucks difference between em so just get the better ones.
Old 11-10-2004, 12:27 PM
H82BBad's Avatar
I am with Bo. However I would caution against running them with as little lash as comp recomends.
Old 11-10-2004, 12:30 PM
zamboxl's Avatar
lash???
so go with pro magnum???
Old 11-10-2004, 01:09 PM
94form2000z's Avatar
If the High Energy are the "R" lifters I personally would stay away unless they are absolutely needed.
Old 11-10-2004, 01:55 PM
zamboxl's Avatar
well iam most likely gona go with the magnums. but why stay away from the R's and what is lash???
Old 11-10-2004, 02:11 PM
Lash is the preload preload pn the lifter and there are many contradicting amounts being thrown around right now for that lifter. Just to much of a pain in the *** MHO.
Old 11-10-2004, 02:19 PM
zamboxl's Avatar
is that only on teh high energy or all of them, if i go with the magnum will it be ok, or should i do something when i get them for the lash or what ever to be good??? please escuse my noobness i think i was thrown ou of the noob section to early. lol
Old 11-10-2004, 02:29 PM
I belive the magnum are like the stock ones torque to 20lb. and be done with it.
Old 11-11-2004, 10:20 AM
Unaffliated Racing's Avatar
the pro magnum lifters are the "R" series. The high energy is a stock OEM replacement type. The "R" series requires only .002"-.004" preload hot, so I would do about .008"-.010" cold. Lash and preload is not the same thing. Don't confuse the two..it will get you into some trouble.
Old 11-11-2004, 10:31 AM
Thanks for the info.
Old 11-11-2004, 11:40 AM
marc_w's Avatar
Not to hijack, but what are the advantages to any of these lifters?
Old 11-11-2004, 11:47 AM
Bo White's Avatar
The R lifters have a heavy duty locking retainer that holds it together and has nicer rollers on them. Other than that the ones that I am looking at they are identical(cc850 vs cc875).
Old 11-11-2004, 01:11 PM
zamboxl's Avatar
ok now iam confused i am getting the pro magnum now acording to comp cam they should be dipped in w 30 for like a half our before being installed, now what else do i need to do?? would i just put them on like if i was putting stock replacements. I am not the most experiecne gear head around as you all can tell actually i don't even think i cuallifie as a gear heal lol so how bout setting me straight fellows. what do i need to do???
Old 11-11-2004, 01:14 PM
Bo White's Avatar
Clean em real good out of the box and soak em in some good 30w like Castrol or what ever then slide em in.
Old 11-11-2004, 01:19 PM
zamboxl's Avatar
cool thanks
Old 11-11-2004, 02:05 PM
the comp "R" lifters(875-16) are the ones that have the small preload. The 850-16 you can just torque to spec. 22ft/lbs
Old 11-11-2004, 07:00 PM
Z06er's Avatar
I went with the stock OEM replacement, the 850's as I retained the stock rockers and plan on using a mild cam.
Don't forget the pushrods which are probably the weakest link in the LS1/6 valvetrain, Comp makes the excellant Hi Tech's which are available in a variety of lengths to suit your needs. Comp also has a handy pushrod length checker which is well worth buying.
good luck!
Old 11-11-2004, 10:10 PM
zamboxl's Avatar
good luck!
Well tell em what you guys think of these. I got a 224,224 Thunder racing cam, i want to get the pro lifters along with hardland sharp rockers, they look sweet and seem to have a pretty desent design, and i guess i'll check the comp cam pushrods ( originally i wanted to go with thunder racing pushrods but i'll check comp out.)
Old 11-11-2004, 11:21 PM
PREDATOR-Z's Avatar
Ok guys,
1- the 850-16 CC lifters will handle any lobe and lifts up to .600 very comfortably, so 875-16 CC "R" lifters are not needed.
2- CC recomends that adjustable rockers are used with Comp "R" lifters. (pro-magnums) so do not use them with non adjustable rockers, "search and you'll read why"
3- TR p-rods are fine and I believe cheaper.
Quick Reply: comp cam lifters
