pics of rear-exit under axle true duals
Old 11-10-2004, 10:56 PM
SSideExhLS1's Avatar
Default pics of rear-exit under axle true duals
looking for pics of true duals that exit the rear under the axle, just looking to check the ground clearance of the pipes. im really tired of this loud *** noise inside the car and im ready to do something about it, i want to put rear tailpipes on this thing. ive already seen some, but i just want to see a few more
thanks!!!
Old 11-11-2004, 08:57 AM
Quick 99's Avatar
I just saw an actual thread on side exit duals, however i cant find the link, try a search if you haven't already. I can tell you though that the clearance between the ground and the exhuast no matter how you run it will be relatively slim, but as long as you are not lowered and dont choose like 4" pipe you should be fine
