My ET/Mod data.......
ET and mod data.....
2.10 60' 8.80 1/8th 13.56 1/4......Car was BONE STOCK and full of gas
2.01 60' 8.71 1/8th ???? 1/4......Added K&N air filter and Direct-flo lid w/ same car weight
2.00 60' 8.68 1/8th ???? 1/4......Removed spare tire/jack w/ better weather
1.96 60' 8.54 1/8th ???? 1/4......cutout and short belt w/ belt removed off the a/c, ASP pulley
1.89 60' 8.49 1/8th ???? 1/4.......ET Streets at 16psi cold mounted on Firebird wheels
1.87 60' 8.39 1/8th ???? 1/4.......Vigilante 2800 converter, added Transo-go shift kit, and removed rear seats
1.79 60' 8.21 1/8th ???? 1/4.......Better weather and a hooking track, 15x3.5" Prostars w 165R15's
1.78 60' 8.20 1/8th ???? 1/4.......removed front swaybar and added rr air bag to keep the car from twisting up
1.78 60' 8.17 1/8th ???? 1/4.......!muffler, !egr, !air pump, ported t/b, ported mass air, all done by yours truly
1.6960' 8.01 1/8th ???? 1/4.......removed pass seat, baker hose to get rid of the accordian tube, t/b bypass
1.67 60' 7.81 1/8th 12.09 1/4.......Mac headers w/ true duals, FTRA, PA chromoly K-member, 3.73 gears
1.61 60' 7.77 1/8th ???? 1/4.......restalled to Vig 3600 (#7 pump, AWESOME converter), ET Streets at 16psi cold
1.57 60' 7.53 1/8th 11.94 1/4.......WOLFE swaybar and BMR lower control arms, running car on 2 gallons of gas
1.54 60' 7.47 1/8th 11.84 1/4.......better weather and a well prepped track, Ed Wright programming, 15x8 Prostars on rear
1.54 60' 7.37 1/8th 11.68 1/4.......Yank Thruster Pro 4600, ET Drags at 10 psi cold, !a/c, dynabatt battery, 110/93 gas mix 50/50
1.52 60’ 7.15 1/8th 11.30 ¼…….Meziere EWP, custom Aluminum LCA’s & Panhard bar, VFN Pin-on hood, solid motor mounts, 36” belt setup, Very light car
Raceweight was 3128 on the 11.30 run. Looks like the 2 fastest tracks in SC is Darlington and Jackson. Thats a pretty detailed list of most of what I've got done. Hope you guy's can use this info! If anyone needs help, just holler!
Originally Posted by 00SS4780
Nice runs man! Glad you passed the 20's and went straight to the teen's.
Steve, thanks man! Yeah we jumped right over my goal and went a little faster
Thanks again for the hook-up on the Meziere Race pump. Tell your buddy thanks for me!
Originally Posted by SPANKY LS1
You forgot to mention the nitrous. LS1s can't run that fast without nitrous.
Shawn
Shawn
