Cheapest, most streatable way of going low 10s NA and 9s on nitrous?
Old 11-11-2004, 09:14 PM
HotRod68Camaro's Avatar
Default Cheapest, most streatable way of going low 10s NA and 9s on nitrous?
I am looking into going low 10s NA and 9s nitrous. Its in my 68 Camaro. I dont want to run a blower. I would like great driveability since this is my daily driver.
Suggestions?
Thanks
Kyle
Old 11-11-2004, 09:21 PM
eric01ss's Avatar
what size motor it is you have because that can mean alot?
02WS6Bird's Avatar
Turbo lol...if not a power adder then try a stroker or Heads/Cam+Weight reduction
Old 11-11-2004, 09:25 PM
Beast96Z's Avatar
Alot of it will have to do with you race weight and your suspension. Since your wanting to stay less radical and more streetable, these will be your key factors. I would reccomend a 408 short block with a set of TEA Stage 3 heads with optional nitrous exaust port. Those 2 compiled with a nice direct port nitrous kit should feed your fury. A 244/248 114 cam would go well and be streetable, along with being very nitrous friendly.
Old 11-11-2004, 09:26 PM
right now iv got a stock ls1. I could get a new engine if that would be cheaper. could you give me specifics on stoker/bore and heads (stage?)
Thanks
Kyle
Old 11-11-2004, 09:45 PM
eric01ss's Avatar
Default heads and cam
hey man go to afr heads website and check out there heads package they had a ls1 dyno at about 540 h.p and show everything they used. Nice car by the way why dont u post some pics.
Old 11-11-2004, 09:48 PM
Ill get some good ones tomorrow and post.
Old 11-11-2004, 09:59 PM
eric01ss's Avatar
all right then nice talkin to u and those afr heads flow real good going to use them on my 420 for my 69 nova
Old 11-12-2004, 10:42 AM
wickedwarlock's Avatar
Let's see that nice ride.
Old 11-12-2004, 10:44 AM
kumar75150's Avatar
low 10s NA cheap
hmmmm
Old 11-12-2004, 11:08 AM
68birdls1's Avatar
i was just about to say 10's and cheap dont belong in the same sentence lol
Old 11-12-2004, 11:15 AM
Another_User's Avatar
Define cheap. Cheap means different things to different people. And if you are ready enough to spring for a new engine, "cheap" by your definition may be possible.
Old 11-12-2004, 01:04 PM
LS1Tech Sponsor
hellbents10's Avatar
Well if racewieght is relitively low, you are still ooking at a $3500-4000 big cube iron shortblock 402,408. Then a nice direct port setup. You are lookin to spend another $2000 or so on heads and the cam and valvetrain of coarse and a big $$$ n20 kit. Along the lines of a NX direct port fogger with a seperate low pressure fuel system. So cheap is gonna be hard, espeacially reliable. This is why not everyone is going 9's on streetable cars.
Old 11-12-2004, 02:53 PM
I ment cheap as in as cheap as possible for good reliable equipment. Would it be possible to do it w/ a stock block w/ forged internals .05 over w/ heads and cam. My weight should be about 3100 with me in the car. w/ 4.10 gears.
http://memimage.cardomain.net/member...60_67_full.jpg
http://memimage.cardomain.net/member...60_66_full.jpg
The car was supposed to get back from the shop today but they broke some wheel studs. Ill get more pics when i get the car back.
Kyle
Old 11-12-2004, 03:11 PM
LS1Tech Sponsor
Thats pretty light. I would say you could go to mid 9's or better with a stock block and forged internals. Just get some nice heads and hold everyhting together with studs and bolts of the highest quality. What trans do you plan on running. Do you have the block yet? I am willing to bet you could get a 6.0l block cheap enough, Build something close to stock cubes and use a inexpensive crank and rod setup from eagle, and soem nice pistons with hellfire n20 rings. A set of 5.3l heads with a bigger intake valve or both would get the compression up there for the n20.
BTW that is one hell of a nice looking 68'
Old 11-12-2004, 08:26 PM
What horsepower & torque range would get me to low 10s? It's an M6 w/ 4.10 but might upgrade to 4.30 12 bolt.
Thanks
Kyle
Old 11-13-2004, 04:56 PM
That's what she said...
TheBlurLS1's Avatar
HPE has a stock shortblock car running 9.6x w/ heads/cam and a TNT kit. check it out in the texas section. but that thing is bound to come apart after a while. you could spray it untill it takes a , then go from there!!
btw - i have that same jack!!
Old 11-13-2004, 05:34 PM
2MuchRiceMakesMeSick's Avatar
All I see is talk about motors. Dont forget rear end, transmission, driveshaft, tuning, tires, light weight rims, and suspension.
Its hard to do it cheap. If it was easy everyone would do it
Old 11-13-2004, 05:45 PM
PunkNPonys's Avatar
Well i just wanted to say that is a badass ride man. I want to do the same thing one day to a 69 camaro. I am sure a nice set of heads and a cam with your raceweight should be 10s NA. Well goodluck.
Old 11-13-2004, 05:59 PM
WILWAXU's Avatar
Like said above..
You've already got a good raceweight. A good set of heads & cam could get you into the 10's once you get the suspension sorted out.
Of course with the T56 you going to need some practice too..
