GTP stg. II what cam
Old 11-11-2004, 09:48 PM
RK2K2WS6's Avatar
Default GTP stg. II what cam
I just bought theses heads milled .50 what do you think the best cam i could run with theses heads be that will work without hitting
Old 11-12-2004, 11:42 AM
RK2K2WS6's Avatar
anyone. My car now currently has the C1 cam but it is cam only it made 384 rwhp and 379 ft.ptq. any help i would appreciate
Old 11-12-2004, 11:53 AM
44mag's Avatar
try the gm asa cam 226/236 duration .525i .525e. 110 lobe sep. it should make good power especially under the curve. losts of duration and it should clear the pistons with no problem. i made 370hp with stock heads through cats, and stock pulley, stock throttle body etc. with all the bolt ons and no cats i think 440hp is obtainable with a good set of heads. also you will never have to worry about changing valvesprings.
Old 11-12-2004, 12:59 PM
MARKSZ71's Avatar
at least a 226 226 camshaft
Old 11-12-2004, 02:27 PM
1QWIKZ's Avatar
you made that power after the head swap? i would look into a cam with high 220s/ low 230s duration on a 112lsa. your best bet bwill be to pick a cam according to your flow #s. if anything call craig at GTP, he has some cams that work well with his heads or you can go to his website for more cam choices..
Old 11-14-2004, 02:45 PM
RK2K2WS6's Avatar
no 384 was a cam only stock heads. Do you know there number and or website.
Old 11-15-2004, 07:24 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
384/379 cam only with a C1 on stock heads is stout. I'd run that same cam with the new heads and see what you get.
Old 11-15-2004, 07:42 AM
PREDATOR-Z's Avatar
1/2 inch mill????
You mean .050
I hope your pistons are notched deep.
Old 11-15-2004, 05:37 PM
1QWIKZ's Avatar
gtp-racing.com or call craig at (713)266-1320. he is a cool guy and will help you out as much as possible.
Old 11-15-2004, 08:39 PM
Stu'sWS6's Avatar
Call Craig and see what he thinks-The "pig" cam from gtp or any of the Thunder racing cams should work well with those heads.
I went 123 mph with gtp stage II's and a tr230, untuned w/ stock 26lb inj.; the car weighed in @ 3350.
Good luck
Old 11-16-2004, 10:06 PM
RK2K2WS6's Avatar
Thanks guys for the info. And yes i mean .050 milled. Dont want to flycut the pistons.
Old 11-17-2004, 06:50 AM
PREDATOR-Z's Avatar
Ok,
Assuming those are GTP LS1 stage 2 W/ .050 mill will give you ~ 59.53 cc chamber (.007 mill for 1cc). Which = ~11.3 CR
With that much mill, you will be very limited as to the choice of cam and the biggest might be in the neighbourhood of 224 duration depending on the head gasket you choose.
Do contact a sponsor to verify this. (actually a couple)
Old 11-17-2004, 07:12 PM
1QWIKZ's Avatar
mine are milled .055..definately check p/v clearance
Old 11-17-2004, 08:07 PM
Mirek's Avatar
Stick with that cam.
But you may even have to notch them with that cam. 222/222/566/566 112 & 286 Adv duration. I hit two pistons on the stock heads with it. Just don't over rev.
Old 11-17-2004, 10:25 PM
RK2K2WS6's Avatar
What do you mean over rev, hitting the limiter or dont up the llimiter
Old 11-17-2004, 10:31 PM
PREDATOR-Z's Avatar
Duhhh!
Old 11-17-2004, 10:36 PM
RK2K2WS6's Avatar
so which is it uping the limiter or hitting the rev. iv bangged the kimiter plenty of times on those cold days when it just ripps the tires off. Stu were your heads milled at all.
Tranzaman00's Avatar
I think he ment don't get the rpms to high, meaning don't redline it or hit the limiter.
