)2 sensor question. Is it better to use the extensions or just buy longer 02 sensors
I tried cutting/splicing my replacement 02 sensors, but was told by a tuner that would likely afect the resistance and thus the accuracy. I have purchased longer ones from NAPA (about $80 each) that seem to work OK. I found a webiste that sells )2 sensors for about $60 for 2000 Z28. The extensions at supporting vendors are about $16-$22 each. Is there any problems using the extensions OR the longer ones from NAPA? Thanks
SDB
SDB
Moderator
The only place the resistance matters, is to the heaters.
The sensor legs themselves feed a very high impedance
input pin pair and your crimp-job would have to be for
schnitzel, to make a difference. Unfortunately the wire
for the O2s doesn't like solder.
If you're doing this for headers I think you should go for
the 'vette O2s that have the longer wires, standard.
Maybe these are what your long-wire ones are, already.
Several recent posts about the 'vette part numbers.
