Whats going on with my MAF.. screenshot inside
I went and dyno'd my car today. I was logging each run with HP tuners and noticed that my MAF reading was acting crazy. At lower RPMs and part throttle it was barely reading anything then at WOT it would start spiking to zero and back above 6,000rpms. I have a screenshot of the log below. I took the maf off and cleaned it.. that didn't make a difference at all. Do you think the MAF is going bad?
Originally Posted by wrencher
Could be a bad maf or a bad connection, I'd test it at the maf w/ a scope. That takes the PCM & the out of the quesswork.
Moderator
The "5V" line is really a pullup load to 5V and the
MAF output is an open-collector driver that pulls
down a narrow pulse. I'd push a sewing needle
through each of the harness wires and clip the probes
to those, look for intermittent wierdness on the output
and the +12 power (esp. with wiggling the connector).
That's how I put the 'scope to mine, anyway (just for
educational purposes).
Originally Posted by Billiumss
It's a problem with the scanning software and HP Tuners knows about it. I have only seen this on Forced Induction cars.
If your A/F is good and you don't have any knock, I'd say your OK.
Hopefully HP Tuners will fix this bug in thier next release.
