your recommendation
your recommendation
Hi gauze I need ask about MTI stealth camshaft 581/581 left 116 lsa?
The rocker arms is importee?
What the pest combination ?
Can I use LS6 camshaft with 1.60 /2.080 valves ?And what the pest cam with this valves ? (i need the cam his LSA more 115)
Originally Posted by blazeone
Stock rocker arms will work fine. Th MTI cam will make a lot more power than the LS6 cam. Stock heads are fine although you will need new springs.
Thank you ............
