I need a camshif help
I need a good CAM
HI
Help my pleez I need A GOOOD CAM for BIG HP POWER FOR
CAMAROSS 99
Patriot Performance GM LS6 5.7L Stage II Head 2.055/1.57/64cc
6speed
SLP (FlowPac)
LS6 intak
FLOWTECH LT
3 IN Y PIP
BORLA
3.4 ger
CAMAROSS 99
6speed
SLP (FlowPac)
LS6 intak
FLOWTECH LT
3 IN Y PIP
BORLA
3.4 ger
if you search, you will find alot of info on what you want. and also check out the dyno area.
but in my opinion, i think a tsp or futrual would be the way to go. dont know any in particular, but i have heard nothing but good things about each company when it comes to makin big power
HI
I need a Gooood cam for BIG HP Power for my
CAMAROSS 1999
Patriot Performance GM LS6 5.7L Stage II Head Bare (2.055/1.57/64cc)
SLP Puly
SLP (FLO PAC)
SLP OIL PUMP
LS6 Intak
Taylor 10mm
FLOW TECH LT
3 Inch Ypip
BORLA
CAMAROSS 1999
SLP Puly
SLP (FLO PAC)
SLP OIL PUMP
LS6 Intak
Taylor 10mm
FLOW TECH LT
3 Inch Ypip
BORLA
[QUOTE=68birdls1]if you search, you will find alot of info on what you want. and also check out the dyno area.
but in my opinion, i think a tsp or futrual would be the way to go. dont know any in particular, but i have heard nothing but good things about each company when it comes to makin big power[/QUOT
so wat cam do you say that its good for my camaro
I would suggest that you read JRP's cam guide, found here. Then, once you understand more of the basics about cams and hopefully having some idea of what you're looking for, browse/search through the LS1/LS6 Internals section and the dyno section(for power gains) to find a cam that will fit your goals.
Questions you'll need to know the answer to before you start searching for a cam is: Do you have an A4 or M6 tranny? Does it need to pass emissions? Are you going for street power or a drag car? Maybe some of both? These different purposes all require somewhat different cams. What kind of drivability are you looking for? Those are some of the basic questions you'll need to answer before you start hunting for a cam. Good Luck!!
You can't just ask us what's the best for YOU. What are your goals? Max power cam with big rough choppy idle would be the T-Rex. It's a monster. On the other side you have the 220/220 series cams. Good luck on your hunt!
Originally Posted by camaro_SS_81
HI
CAMAROSS 99
6speed
SLP (FlowPac)
LS6 intak
FLOWTECH LT
3 IN Y PIP
BORLA
3.4 ger
CAMAROSS 99
6speed
SLP (FlowPac)
LS6 intak
FLOWTECH LT
3 IN Y PIP
BORLA
3.4 ger
