Long Bolt for pulley install is stuck...
Old 11-15-2004, 03:29 PM
ws.6kid's Avatar
Exclamation Long Bolt for pulley install is stuck...
I am in the middle of a cam install and the long bolt to put the pulley on is stuck (wont untighten or tighten). This is a stock pulley and it as never hammerd in by anything. It got torqued down with a 1/2 impact and then it got stuck. I have searched but have not really found the answer to this. I have been told it is more than likely the inside of the crank threads got stripped or the bolt itself got stripped?
I was told by a shop that they would have to pull the motor out and replace the crank if it was stripped!!
Has anyone else had this problem??
Old 11-15-2004, 03:51 PM
conan's Avatar
Were you puting the pully back on? When i did my cam swap I bought the longer arp bolt Because i was told the stock bolt was not long enough to get the threds started. "wich was true" .
Old 11-15-2004, 03:57 PM
ws.6kid's Avatar
I got a longer bolt that came with my cam kit from TSP. Everythings is in except for the damn pulley...
Old 11-15-2004, 04:02 PM
conan's Avatar
Might want to hose it down with wd40 and get a long braker bar and very carefuly try to move it back and forard to try to loosen it up. If you were putting it in with the air wrench you might have gotten it cross threaded. Take your time Good luck.
