ASA Cam with Nitrous
Old 11-15-2004, 07:59 PM
Dragula's Avatar
Lightbulb ASA Cam with Nitrous
No I don't have this setup, but with a low lift cam I think you could get away with stock heads, (No need for high flow at high lift heads with a low lift cam) and a 100 or 150 wet shot of nitrous.
I think the 236 exhaust duration compared to the 226 intake duration would work great with nitrous, plus I won't have to spin the engine past 6400 RPM's
What do you think?
Is 400 HP w/o nos and 500 - 550 HP with nitrous possible?
Also, will my bottom end hold up?
Old 11-15-2004, 10:29 PM
44mag's Avatar
look up threads on the asa cam. one person had the asa cam with full bolt ons, gmpp ls6 heads, and a small shot of nitrous and run 10s with a full weight auto car. i believe george benson is his name. i believe there are better choices for nitrous because the asa has a tight lobe sep. angle (110lsa). but im know you can make 400rwp with full bolt ons and the asa cam with an m6. also the bottom end should be fine as long as you have the car tuned for the nitrous.
Old 11-16-2004, 08:45 AM
93Polo's Avatar
Cammin Beasst ran some good #s with an ASA cam and nitrous.
Quick Reply: ASA Cam with Nitrous
