Can i fit a 15x10 with sportline springs???
My SS has Eibach Sportline Springs i am wondering if a Weld 15x10 will fit or if i will have to run 15x8 instead just ordered some skinnies now i just need the back.Believe it is a bout 1.5" drop in the rear.
Thnax BTLFEDSS
Thnax BTLFEDSS
It should fit. I run the pro-kit and 15x10
My best friend runs the sportlines with 15x10 bogarts with no problems.
We both did have to roll our fenders. He had to bang in the inside behind the wheel just a tad because he rubbed.
Wow both of ur cars are hot u guy's must get alot of looks.but my next question is do you just stick the bat between the tire and wheel lip and have some one hold and roll the car slow?Any help with this would be awsome
Thanx
Thanx
Originally Posted by z28kid98
thought i remember reading somewhere to take an x-acto knife and slice the paint right along the underside of the lip so that when you roll it it doesn't chip the paint, just seperates at the "cut" line.
Chris
Chris
yes as far as i understand this is how you do it. cut 3/8 from the wheel well on the lip. Then tape it up with masking tape. Then try to get teh rear end as low on the ground as possible (as many freinds as you can put in teh back) And then SLOWLY roll the bat.
