cam ?
Old 11-16-2004, 06:59 PM
slow98Z's Avatar
Default cam ?
I am installing an 01ls6 cam in my 98Z28 and was woundering if the base circles are the same on my stock cam and the ls6 or will I need different push rods
Old 11-16-2004, 07:03 PM
conan's Avatar
Are you changeing your springs?
Old 11-16-2004, 07:04 PM
git_sum's Avatar
not sure what base circles are but i dunno why you'd have to change pushrods. I know when i bought a cam i didn't have to use different lenth pushrods and my cam is much larger than the 01 ls6 cam. You should just be able to use the stock 7.4's.
Old 11-16-2004, 07:16 PM
slow98Z's Avatar
my car already has 02ls6 springs and titanium retainers
Old 11-16-2004, 07:21 PM
conan's Avatar
Like gitsum said your stock ones should be fine. I have thunders hardened 7.4 length works fine.
Old 11-16-2004, 07:27 PM
LS198Z's Avatar
The base circle is smaler but when I had my ls6 cam in the 7.4s worked fine.
Old 11-16-2004, 07:34 PM
slow98Z's Avatar
how much smaller?
Old 11-16-2004, 07:43 PM
LS198Z's Avatar
I searched and found it is 19mm vs 19.7mm. I don't know if that is true or not.
Old 11-16-2004, 07:46 PM
slow98Z's Avatar
So 7.45's are the right ones?
Old 11-16-2004, 07:48 PM
LS198Z's Avatar
I would use the 7.4's
Old 11-16-2004, 07:54 PM
slow98Z's Avatar
Thanks!!!
