Stereo & Electronics - will this amp work?
brandon1221
11-16-2004, 07:00 PM
I am planning on gettin a stealth box with a JL audio 10w3 V2 sub, i was wondering if this amp would be a good amp to go with it:
phoenix gold zx350, specs are:
110x2 into 4 ohms
175x2 into 2 ohms
350x1 bridged into 4 ohms
brandon1221
11-17-2004, 08:45 PM
anyone have any input on it?
tuffluck
11-17-2004, 09:12 PM
i think the jl sub you have is a 2 ohm sub, so if you are going with that amp, you'd either need two of those subs, or you'd need one SVC sub at 4 ohms instead.
01WS6/tamu
11-17-2004, 11:01 PM
Do not hold me to it but I think the Phoenix amp is mono two ohm stable. If your sub is a two ohm DVC you can series parallel the two coils to get 4 ohms mono. Or run the amp in two ohm stereo with one coil on each output.
brandon1221
11-18-2004, 01:08 PM
the 10w3 is a dual voice coil and each coil has 2ohm. Which would make it 4ohm right? So would this figure apply to that: 350x1 bridged into 4 ohms, or is it not bridged if there are 2 2ohm voice coils?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
