853's
Old 11-16-2004, 07:31 PM
slow98Z's Avatar
Default 853's
are they beter than stock 98 heads.Got them off Ebay for $100.00.
Old 11-16-2004, 08:52 PM
PREDATOR-Z's Avatar
If so it is meaningless improvements. But they are a good base for porting.
Old 11-16-2004, 09:11 PM
Timberwolf's Avatar
according the book I have, the 853 was used from 97-00. So you may be replacing 853 heads with 853 heads...only difference being the valve cover bolt pattern
Old 11-16-2004, 09:16 PM
LS1TECH Sponsor
badpewter-z's Avatar
853's are defiently earlier i believe 99-00 just took them off my car
thought 00's had better heads guess not , i never looked at the number till then
Old 11-16-2004, 10:32 PM
BlueSix's Avatar
Some of the '00 cars got the "better" 241 heads.
Old 11-17-2004, 05:44 PM
Moderator
davered00ss's Avatar
98-99's got 801 heads. Don't know if they flow any different. Bolt patterns are different on 00-02 heads than 98-99 heads.
Old 11-17-2004, 06:44 PM
DaleMX's Avatar
97 to 98 used the perimeter bolt valve cover and 99 and up used the center bolt valve cover. All the heads are interchangable on the block, just have to have the proper valve covers.
I believe the 243's started around mid 2000.
Old 11-17-2004, 10:08 PM
BlueSix's Avatar
243's are LS6 castings.
Old 11-18-2004, 11:51 PM
fastsspr's Avatar
i think i so an article in a magazine saing there is a difference in flow betuine years and heads!!!
Old 11-19-2004, 12:45 AM
PREDATOR-Z's Avatar
In stock form, yes; but once ported they can all perform the same.
01/02 f-body 241 castings in stock form flow a little better than 853.
Old 11-19-2004, 03:14 AM
DaleMX's Avatar
Oh yea, meant 241's
