Eliminate EGR and AIR?
Old 11-17-2004, 10:44 AM
RollinSScamaro's Avatar
Default Eliminate EGR and AIR?
I am doing an ls6 intake swap right now.. and i plan on making a small steel plate to block it off on my passenger side header.. but i was wondering if it is worth blocking off the check air valves or not? What would be the gains or benefits from it? I have heard of people blocking them off and drilling small holes in them? I don't really get the whole concept.. What else would i need to remove if i blocked the check air valves off? The vacuum line? Or is there more? Any help is greatly appreciated.. working on the install right now.. trying to make some decisions! thanks
Old 11-17-2004, 10:53 AM
conan's Avatar
It saves weight and makes for a cleaner engine bay. I dont beleve there is any power benifit. But it does take alot or the cluter away.
Old 11-17-2004, 11:38 AM
Z28Venom's Avatar
www.ls1camaro.net has a write up on how to go about removing everything. I'm too lazy right now to find the direct link, but it's over there.
Old 11-17-2004, 12:42 PM
Tranzor's Avatar
There's no real benefit to removing the AIR pump other than taking a little bit of weight out (not a whole lot, less than 10lbs), but the biggest reason to do it is to clean up the engine bay... makes for changing the spark plugs a little easier.
Old 11-17-2004, 01:21 PM
STRIPSTAR's Avatar
You wanna sell me your EGR tube since your taking it off? I just need the tube from the intake manifold to the egr pump.
Old 11-17-2004, 01:59 PM
alright i'll probabaly buy a block off kit for the EGR and AIR then.. Yea i'll sell you my Egr Tube when i'm all done.. just send me and PM and i'll remember for you.. Thanks
Old 11-17-2004, 02:03 PM
seadoo's Avatar
I blocked both of those off... and made a aluminum plate to go over the intake and tapped a small hole for the screw to hold it to the intake along with RTV sealer. my headers are race headers, not even provisions for the EGR or AIR
Old 11-17-2004, 05:29 PM
Another_User's Avatar
Take the EGR off of cammed cars, do not take off AIR at all. Unless you are not running catalytic converters. If you are running cats, they will last longer with the AIR system, and you will have better emmissions at startup. If you have a non-cammed car, leave EGR because it cools the cylinders and allows more spart advance at low throttle. On cammed cars you already have exhaust reversion diluting the mixture, so EGR just hurts and needs to be removed.
Old 11-18-2004, 08:45 AM
Well i removed the cats on my car..and have a cam.. so should i remove the AIR and EGR then? I made the block of plates last night for the 3 plugs.. thanks for the replies
Old 11-23-2004, 04:28 AM
ninobrn99's Avatar
hmm i have cats on my TD's, but no AIR provisions..do i need to keep the AIR??
Old 11-23-2004, 04:35 AM
Keenov's Avatar
Depends, are you using the cats to quiet the exhaust or are you using them for emissions.
Old 11-23-2004, 04:41 AM
ninobrn99's Avatar
not too sure...ill have to ask the precvious owner I think it was just to quiet it down..besides, Ill just buy them one at a time and replace them later on
Old 11-23-2004, 04:44 AM
ninobrn99's Avatar
what would happen if I didnt use block off plates? Im going to install the intake and then take it to the shop to get the headers installed the next day.
Old 11-23-2004, 05:32 AM
Keenov's Avatar
No block off plates on the headers would be an exhaust leak. No block off plate on the intake manifold can cause unwanted/dirty air to enter and unwanted air to escape.
Old 12-23-2004, 04:13 PM
81LS1Camaro's Avatar
I just cut the tubes off of the origianl flanges for the egr stuff. Then I TIG welded a short tapered head stainless bolt in the holes were the tubes entered. I bought a plate for the intake, but they are just a plate with a bolt hole in them that you seal with silicone. Should of just made one
Old 12-23-2004, 06:28 PM
That's what she said...
TheBlurLS1's Avatar
use an adjustable freezeplug for the intake manifold. looks like to washers connected together with a bolt and a big piece of rubber between them. turn the bolt, expand the rubber, and it seals in intake manifold.
Quick Reply: Eliminate EGR and AIR?
