View Full Version : LT1 and LS1 backing plates the same?
gomer
11-17-2004, 01:04 PM
I used the backing plates off my stock 10 bolt to install my piece of shit moser with... I have a 3.42 rear out of my old 96 T/A that I want to install in my car for a week or two, does anyone know if the backing plates on the LT1 rear will work with my LS1 rear brakes?
1fastWS6
11-17-2004, 01:18 PM
Nope. Different brakes. You'd have to run the LT1 calipers/rotors also.
I just put my stock rear, DS, torque arm back in the car this week while I'm deciding what to do with my 12 bolt. Fortunately I bought an extra set of LS1 backing plates a couple months ago.
See if you can get some from a bone yard. Most have the complete rear brakes, backing plates and all for $150-$200.
gomer
11-17-2004, 01:37 PM
What if I pull the backing plates off the LT1 rear end and install them onto my LS1 rear that doesn't have any plates on it?
1fastWS6
11-17-2004, 10:48 PM
Unless I'm misunderstanding you, that's not going to help you. The LT1/LS1 axle housings are the same AFAIK. Only difference is the brakes. See if you can scrounge up some LS1 backing plates.
