Just what everyone wants to see!! Another cam?
OK I've done some searching and before I make my final decission what is the best,Biggest,Most powerful or in that area, you guys would reccomend for someone that will be running stock heads for a while (quite awhile!). Also I don't want to do any fly cutting. Is there a cam that will work nicely with stock heads and also work with some stage two heads just as well or better? Basically I would like to get a cam that I can keep when ever I can afford heads.
Thanks,
Shane
Sorry for another cam ? I have been holding of for a while now on posting this thread but not knowing much about them the more searching I do the more confused I get. I want that classic cam sound (choppy and loepy) and I want it to go fast. I want the car to be snapy and respond quick and really wont be pushing the rpms to much so I guess something that works in the lower to mid range.
Thanks,
Shane
The TSP 231/237 works great w/ stock heads. It's called the max effort cam for cars w/ stock heads. Responds well to nitrous too and you won't have to spin to 7500 rpms for peak power.
I hear ya. What does the +2 mean. By the way I got my sound clip up finally of that custom magnaflow job I did. You had wanted to hear it awhile back. It is in the external section under anyone evr tried this. I'm running really rich so don't mind the FIREBALLS and POPS. There is no fly cutting involved with that cam is there?
RPM4 cam 232/236 595/601 on 114+4 LSA
stock engine and LS1 intake and picked up 45 rwhp.
http://www.real-performance-motorsports.com/
Thanks for you opinion, that is a pretty decent gain. Anymore out there?
What makes the 224/224 so popular wouldn't the last to ststed be more powerful?
With a cam such as the RPM4 or the TSP 231/237 you will need tuneing.
I think you should check VHP (sponsor>>>>>) cams.
They are short duration tight lsa cams with good chop-chop idles that meet your low>midrange criteria.
047 (ASP KICKER CAM)or 055 (THE BOSS) cam would be my choice. PM Joe Vinci he will explain more about his products.
find a few cams you like and search for them in the dynamometer results forum. i was looking at the tsp 231/237, but a lot of the results with that cam have (IMO) low torque numbers, when compared to a few other cams (NOTE: i am not saying every result was like this for htis cam, i am only saying what i have learned after searching for dybo results of that cam). that all changes if you will be spraying though, the nitrous should give you all the torque you could want
Thanks for everyones help. From searching it seems like alot of people go with a thunder racing 224, What do you think is the most popular? Popularness in my eyes is somthing that has been proven.
