Crane 1.8 Rocker question
Originally Posted by Batman WS-6
What is the valve lash supposed to be on the Crane gold 1.8 Rockers for an LS1???
first i'll assume you are using a hydraulic cam. as per VHP, the people that helped in designing the rockers with Crane, you want about .060-.120 preload on the lifters. how far down the lifter plunger is pushed down into the lifter. there is zero 'lash' on a hydraulic cam. lash term is used on solid lifter cams. where you have an amount of gap between the rocker and valve tip.
