This is what I found
I went out for a drive and was doing good till a friend and I were messing with each other reving back and forth( you know the game). Then it felt like it just went into neutral. Next day it drove fine for a block or two then the same thing happend. Felt like someone just through it into neutral. Barely made it back home.
I believe your "nuetral" feeling is from a plugged filter, causing loss of pressure. It doesn't take much to clog these filters. You'll have to tear it down to find out what is burnt/broken.
yeah it is definetly a clogged filter and by now it is trashed and needs a rebuild. Sorry Bro, that sucks my suburban just did the same thing. We sawit as a chance to mod it though and we are going to put an Ls1 in it. It is the old body style 1990 4x4. It be called OCII with a huge lift 48 in swampers
