Anyone running this combo
Old 11-19-2004, 04:16 AM
VASTREETRACER's Avatar
Default Anyone running this combo
Absolute Speed 5.3L stage 2 heads 12.1 comp. with Texas Speed 231/231 .595/.595 112LSA on a stock bottom end. if so what type of power are you getting and have you had any issues.
I have decided that I want the stage 2 5.3L heads but am looking for the best cam for the car. The car is a 2000 SS M6 it has Pacesetter LT's, Edit, a lid, and off road Ypipe.
If anyone can sugest a better streetable setup then I all for sugestions. the car is not a everyday driver but will be driven often (mainly on weekends)
Thanks in advance,
Mark
Old 11-19-2004, 07:21 AM
PREDATOR-Z's Avatar
Match the cam to your head flow #'s at mid lifts, or if you decide on a certain cam, match your heads mid lift #'s to that particular cam.
Old 11-19-2004, 04:00 PM
how do I go about matching the cam up with the heads. I have decided I want to get the stage 2 5.3L heads 12.1 compression. My goal is to get 450+RWHP out of a H/C settup, if thats even possable.
thanks
Mark
Old 11-19-2004, 06:04 PM
xttc2000's Avatar
email a cam manufacturer and have a custom one made to your car and those heads.
and with that CR you will need to run race gas to get any kind of timing into it.
Old 11-19-2004, 06:22 PM
CamTom12's Avatar
not if you get a cam builder to address the high compression and lower the DCR a bit...
Old 11-20-2004, 11:04 AM
Ok I know a few guys here in VA. that can custom grind me a cam that have been doing LS1 cams for a while with great results.
