Removing decal glue from paint
Old 11-19-2004, 01:03 PM
Roarin_8's Avatar
Default Removing decal glue from paint
Ok I removed the nasty beige stripe that was on my NBM Z. What is the best way to get rid of the dried glue that is on the paint? Would a car wash do it or do I need something to treat it first? Thanks.
Old 11-19-2004, 01:31 PM
LawmanSS's Avatar
I used 3M adhesive remover that I bought at Pep Boys...you could also use an autobody prep solvent such as Shine On...
Old 11-19-2004, 01:34 PM
Roarin_8's Avatar
3M sounds good since I have to go to pep boys and pick up some coolant. Any special way on applying the 3M?
Old 11-19-2004, 01:38 PM
LawmanSS's Avatar
Not really...I just followed the directions on the can...you just kinda dab it on and let it soak in for a bit and the adhesive will come right off...it can be a little annoying at times because the glue will turn into little gummy ***** as it softens.
Old 11-19-2004, 01:41 PM
Roarin_8's Avatar
Damn those gummy *****!!!
