ve table for SC
A car with a stock engine & supercharger would probably have the same ve table as a stock car. The ve of the engine is based on the intake/heads/cam/headers combo because it is MAP referenced. Also, the ve table is only good to 105 kpa so you couldn't use it for boost anyway without some doing a lot of other stuff. Most cars rely on the MAF for fueling under boost because the ve table gets maxed out at 1 bar.
