Pulley is squeeking.........
After I installed the new pulley tensioner is when I started to have problems, the pulley tensioner is adjustable and the stock one isn't so maybe that the problem, at fist I tightned the tensioner, then changed the tensioner pulley back to the stock pulley and the squeeking went away for a few days, and now the noise is back but worse then before. It now sounds like the pulley right below the power sterring fluid canister is making the noise and not the belt since I tightened the belt more and the noise did not go away. Also is the aftermarket pulley tensioner supposed to get so hot that is burns when touch? Need some advice. Please and Thank You in advance.
The belt is brand new a week old or so. I will check the alternator pulley it seem it can be that one or the one above the alterator pulley, hopfully it's the alternater pulley and not some major problem, im just so dam frustrated because I replaced one thing and now I have to replace another.
update
Took the power steering belt off and the squeeking went away. Using the search butten I found a post and a bulleten number with all parts needed to replace, it says replace belt, alternator bracket and double idler pulley. I will try this and hope it works.the post mentioned this bulletin
As mentioned I will be replacing the parts I listed above - which I have already ordered. But before those parts arrive, I decided to purchase another belt, this time a stock gm belt and guess what.... the squeeking stopped, no bull. And yes, the belt I just replaced was almost brand new, days old. But the gm belt costed twice the price. I will still end up replacing the parts the bulletin advices to change since I already ordered them, but if you have a squeeking belt first try a gm belt, would have saved me some money had I done this first, before I started ordering parts, but having the squeeking gone is not bad at all.
Oh and the problem was not the tensior or the pulley, the falt was the belt all along.
The belt number is #12569527 and you can actually get the belt thru this sites sponer sdcgmparts, for half price.
